Mini Ninjas Demo
So anyone else getting this at all? Is there some obvious setting that I am missing that may be causing this?
My little lad will love this, but I want to sort out this annoying freeze bug thing before I let him loose on it!
You on windows 7
You could try running it in Compatibility mode?
No, not yet. Vista Premium 32...
To be fair, I've not tried out any other drivers (nvidia) yet, and I'm currently using the latetst official ones that I know a lot of other people had issues with. I might try rolling back to my last stable set (186.18 I think??) later, see id that makes a difference.
Notice you have an X-Fi, I'm wondering if it is tied to that as I have one as well? Seems odd we are both getting it but you're on nVidia Vista x86 and I'm on ATi Vista/Win7 x64.
edit: i also downloaded from the mininijas website, not from Steam or anywhere else yet. You?
Got mine from Steam....weird......
Doesn't work for me, double click, goes to load then nothing. No error. No HDD activity. Nothing.
Just been on official site forum and stuttering seems to be connected with USB keyboards??
lol, 'cus they're not common these days are they. :rolleyes:
Seriously, do devs just order a job lot of exactly the same spec PC's for their internal testing these days?
If I can find an adapter I might try plugging the k/b in PS2 later and see if it helps. If not disabling some of the HID devices might work.
Dug an old spare PS/2 k/b out and can indeed confirm that the annoying pausing issue goes away.
Not a bad little demo but it's going to have to get good reviews or be cheap for me to get it tbh. Looks nice enough but fps seems a bit low for what it is, maybe the x2 is not kicking in? Oh, and they'd need to fix this freezing issue for my usb k/b as I wouldn't fancy having to swap out each time I wanted to play it.
Yeah great little game, i enjoyed playing this demo a lot, i will buy it if its -£25.00.
Its quirky and original, using ur hat as a boat and being able to take control of a chicken to lay eggs.. haha great, also love the sounds of all the other little ninjas.
Im also on windows 7 and no problems here
