Windows Update...
13 Apr 2009
isnt updating, I had to manually install service pack 2 then use windows update and it only gave me 25 files, after that it said everything is updated Ive got Windows Vista Ultimate 64bit, hope that helps, or should i just shut the hell up :confused:
I had to update a load of machines behind a dodgy web proxy once that basically broke Windows Update. It was the definition of tedium but MBSA made a bad job a bit easier.
