im jumping. 9800gx2 1gb to ???
1 Jan 2009
hello everyone againg.
i open this post because i need some really pro advice.
i had a 9800 gx2 1gb until last week. the crap got broken. that really hurts to be honest.
well, thinking about tomorrow, we have to move forward and leave past in the past. what card do you recommend me to move to?
i was thinking on a gtx 295 but i dont want to spend 500 usd againg on a card.
what about gtx 285 2gb card? or do you recommend me another card that is in 200 series, that can play all games on super high/highest like the old 9800 gx2 was able to do? because i dont want to get a card worst than the one i had, i want one better with the best price. please help me on this.
my mobo is
HDD:500GB WD 7200RPM,16Mb Buffer.
MB:EVGA nForce 790i Ultra SLI Socket 775
PS:Antec TPQ-850 TruePower Quattro 850W
PROCESSOR:Intel Core2Duo E8400 3.0GHZ 6MCache 1333MHZ
Memory:Corsair XMS3 DHX 4GB(2X2GB) 1333MHZ DDR3
broken video card T_T :EVGA 9800GX2 1GB GeForce DDR3 Serie9
Case:Thermaltake Xaser MX (VH9000BWS)
Logitech G11/G5/xbox 360 wireless joystick
kds LCD 22
I was thinking that too Wayne, EVGA tend to be pretty good with their RMA's so I'd suggest getting in touch with them, see if they cant help you out
sorry i already have some time with the card.
i check but there was no waranty, and i buy it by a third party company as well.
also i remember i overcloked a few times. but i think the card die because of the lifetime.
so please recommend me something good :D
XShido that card can't be that old surely? . . . Have you checked with EVGA your status! :p
Some cards have two, three years warranty or more :confused:
260GTX would give similiar performance to your old card, slightly slower in some cases but has the advantage of not relying on SLI and runs cooler and quieter, it does run faster in some cases too.
IMO either buy a 260/275GTX, 4890 or wait to see what the new ATI cards are good for coming out soon. Unless you have an SLI board or can find a 4870X2 cheap you don't really have any other cost effective options for getting same or worthwhile better performance than your old card.
im using a nvidia evga 790i ultra sli boars.
so yes it is sli, but i didnt had the 9800gx2 on sli, it was that single card.
i want a new card with some better performance that the old one, also i prefer it nvidia based, i dont like ati too much, and my board and processor are based on nvidia mobo so, kind of recommended for me to go nvidia cards.
If you have an SLI board then IMO your options are:
If you play upto 1920x
1x 260GTX or 1x 4890.
If you play at 1920x or above
2x 260GTX in SLI mode
or
Wait to see what the new ATI cards are like.
The 9800GX2 and GTX275 are on the same bar performance wise, and you could always add another in later if you need a boost.
My EVGA 9800GX2 came with a 10year warranty, did you not register it or something ?
i think i didnt register.
is there a recommendation that is not in sli?
just a single card?
Well like BIGBC said, his was similar to a GTX275 so you could go for one of those for around £150.
Next step up from that is the GTX285 and the cheapest ones are around £220 but go up past £300. Quite an increase in cost really! Maybe get a GTX275 then think about adding another in SLI later on if you feel you need to?
ok i was looking for prices.
tell me wich of these cards is on the best price compared to the performance and quality i will get. remember please i used to play ALL in superhigh/highest with my 9800gx2 and i dont want to go play normal quality. just the best :D.
my option$ are.
1. EVGA 01G-P3-N981-TR GeForce 9800 GT 1GB DDR3 - 132 usd
2. EVGA 512-P3-N884-AR 512MB GeForce 9800 GTX + Superclocked DDR3 - 180 usd
3. EVGA 896-P3-1257-AR GeForce GTX260 Core 216 Superclocked 896MB DDR3 -202 usd
4. EVGA 896-P3-1171-AR GTX 275 Superclocked 896 MB DDR3 - 253 usd.
you think ill be able to play anything with the 9800 gt? i mean all in super high? any suggestion?
ok i decided to go for these, which to choose?
EVGA 896-P3-1170-AR GTX 275 896 MB DDR3 - 240 usd
thanks for helping. now which one should i choose?
i like to play all on highest, i use a monitor kds 22 inches. 1680x1050 max resolution (if i remember well XD). or i can use 19 inches samsung tv but this one gets to 1950x dont remember. but ill keep on monitor not tv. so suggestion?
