- 15 Nov 2008
- In the ether
You should have most luck with a USB wireless dongle, as long as it isn't brand new and is pretty well known. Try to do some research before buying anything you can usually find out what chipset a wireless adapter uses before you buy it, and thus if it is supported by the latest and greatest Linux kernel.
On PCMCIA cards, I'd urge caution, there was a significant change in the way PCMCIA cards are handled in the not so distant past essentially a they come under PCI rather than cardbus nowadays and I have no idea how that affected existing drivers
