Hi all, Just finished my new i7 build and got a problem with temps! When I raise the bclk to 20x150 - 3ghz (all other settings are left untouched when I loaded the optimised defaults) the memory is running @ 1200mhz real temps at full load running prime95 blend test go upto 100c and shuts off before it is finished! Do u think I should have applied more thermal paste on the cpu as I only put a pea sized amount on and spreaded it all over so it was a v.thin layer? I have the Akasa 967 which looking at the review on 'bit-tech.net' It says-' the downside of direct contact coolers is that the thermal contact surface isn’t perfectly flat, with the joins between aluminium block and heat-pipe leaving visible gaps between each other. However, in the past this hasn’t harmed performance, and Akasa has done a good job of making the joins as small as possible – a little extra TIM applied to the CPU is all that’s necessary to fill in the cracks. ' Do u think thats my problem as the pins on the cooler are pushed though the mobo properly!
Thanks a lot in advance.
Oh I'm using some Arctic MX-3 I got hold of!
