Nokia 5800 Wifi problem
20 Oct 2002
London
Hey all. I have a 5800 without a mobile internet package. I use the wifi at work and at home, but recently my apps have started remembering the last wifi connection they've used, and then only trying to connect to that one. I have FB and AccuWeather which now won't work at home, because they try to connect to my work wifi. How can i stop this? :confused:
Cant you get it to search for another network and connect to a different one that way. I know mine remembers access points, but it still will search for others if I tell it to.
If I connect to the correct wifi and then load up FB, it'll tell me something like that the wifi is in use and i must disconnect so it can connect (to teh wrong one) :confused:
