Which 16gb USB flash drive?
5 Jun 2005
Southampton
looking to get a 16gb flash drive i currently have Corsair 8gb rubber one, i see there is a Corsair 16GBGT USB 2.0 Rugged one for around £25, just wondering how people have found that or if anyone has any recommendations? not looking to spend any more than £40 and would consider a 32gig if the speeds and price are good.
The Corsair Survivor 16gb is a fast and reliable drive, had mine for a few months now and no problems, far faster than my old PNY 4gb.
I've got a couple of Veho VSD-001 USB to SD/SDHC car readers:-
Buy yourself a 16gb SDHC card and you can swap it between your camera/pc easily. Plus you can interchange the cards (I have an 8gb in the case as well). Also with the adaptor you can use the micro SDHC cards - I use this for my N82.
The Corsairs are very good but the Veho IMO is much better (and maybe faster..... although only my observation).
You can get them for under £3 and use them with non-HC cards as well!
I've got one by PNY, but since I've had three 4gb pny ones die on me I'm not very confident in it and will avoid it in future. OCZ rally is worth looking at, Ive had one for ages now, generally on a keyring, and it's running just fine. Has my ubuntu install on it at present.
