I think that was his point![]()
No i was not comparing it was my first thought when looking at the Sony shots.
whatever you intended it did come across as once you'd seen the d40 pics you felt the Sony cameras were poor.
I'd counter by saying if you based your disdain for a Sony system after looking at 3 heavily processed photos then tbh, your opinion isnt worth that much.
And comparing with the D40 shots above, how can you show me which system is better?
What tosh. The shots above are so processed and so far from the original image it's not even funny! Simply nothing you couldn't achieve with the Sony, the right lens and sometime in Photoshop
cheeez this is getting a little like the console forum.
Pull ya neck back in m8 i was talking about the sony shots do nothing for me.
2 mins on a non-specialist site found 2 different 300mm f2.8 lenses. One Sony one sigma. A few mins more I found a 600mm f4 prime minolta AF
I can't see any reference to the 600mm f4 which suggests to me its not a mainstream lens.
I wouldn't call anybodies' 600/4 a mainstream lens ...I can't see any reference to the 600mm f4 which suggests to me its not a mainstream lens.
	In my situation, where money is tight (I'm a 17 year old earning around £350 a month normally, and having to run a car apart from petrol), I am honestly swaying towards the A200 over, say the 350D... would you still disagree?
These are available readily/easily and cover all basis for the beginner!
So the argument that lenses for Sony camera's are not readily available or a lack of need to stop!
Was 16 when I got a 350D... Im 19 now with £2.5k of kit.
Get Canon/Nikon.
Bit late now, he's got the A200.
What about other fantastic wide angle lenses like the tokina 11-16 f2.8 and 12-24? What about a 50mm f1.2, 85mm f1.8, what about the 50mm f1.8 costing nearly twice as much as the Canon or Nikon equivilents.
The 135mm f2.8 costing more than the 135mm f2 L and the zeiss f1.8 being twice as much and so on.
What about having nothing between the consumer range 70-300g and the pro 70-200 f2.8?
What about the lack of choice with long primes apart from sourcing older models?
What about the higher cost associated with Zeiss lenses?
Yes there are some advantages to a Sony, like being able to use older minolta lenses without an adapter. That's great. But you make out like there are no issues whatsoever.
