How much to tighten Prolimatech Megahalem when fitting
24 Jul 2009
Lost in Alps
I've tightend mine as far as it will go. No problems, highest temp using Prime 95 and IntelBurn... 61.
I also used the Prolimatech recomended method of spreading the supplied paste
I haven't used the Megahalems personally, but all screw down HSF's I have used can only be screwed down so far anyway, so I just screw mine down as far as the screw allows me to.
Bulldog, what temps do you hit with your Megahalems at 4.2GHz?
Anyone with advice on method to use for MX-2 on core i7 with Megahalem, considering going with the line method recommended by Artic Silver.
Pretty sure most people just put a small blob in the middle of the chip and then put the HSF straight on top. This is how i did my last one and its been working fine for the last 2 years.
