- 17 Oct 2002
- Stoke
Samsung F2080 20" Widescreen LCD Monitor
The Samsung F2080 20" 16:9 widescreen LCD display features cPVA panel technology for accurate professional-caliber colours. With 100% support of sRGB colour mode and 178º viewing angles, the colour will be smooth and accurate to everyone gathered around your screen. High 150,000:1 contrast ratio provides subtle transitions in shadows, and details in the whites and blacks. The 2.5mm bezel-to-screen depth and the 15mm ultra-narrow bezel combine to give you an even, virtually seamless display area when tiling multiple displays. And the Tilt / Swivel / Pivot / 130 mm height-adjustable stands also add comfort.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 150000:1
- Brightness: 300cd/m²
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 2x DVI-D
- VESA Compliant
- Adjustable Stand
- Dimensions: 474.1mm x 357.6mm x 197.0mm
- Weight: 5.5kg
- Warranty: 3 Years On-Site
Just £195.99 Inc. VAT
BUY NOW
Samsung F2380 23" Widescreen LCD Monitor
The Samsung F2380 23" 16:9 widescreen LCD display features cPVA panel technology for accurate professional-caliber colours. With 100% support of sRGB colour mode and 178º viewing angles, the colour will be smooth and accurate to everyone gathered around your screen. High 150,000:1 contrast ratio provides subtle transitions in shadows, and details in the whites and blacks. The 2.5mm bezel-to-screen depth and the 15mm ultra-narrow bezel combine to give you an even, virtually seamless display area when tiling multiple displays. And the Tilt / Swivel / Pivot / 130 mm height-adjustable stands also add comfort.
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- VESA Compliant
- Adjustable Stand
- Dimensions: 545mm x 476.5mm x 216mm
- Weight: 6.3kg
Just £242.98 Inc. VAT
BUY NOW
- VESA Compliant
- Adjustable Stand
- Weight: 5.5kg
BUY NOW
- VESA Compliant
- Adjustable Stand
- Weight: 6.3kg
BUY NOW
