First post, long time lurker and researcher.
Had the 4.0Ghz overclocked bundle for a couple of days and have noticed that the fan speed when attached to the Gigabyte EX58-UD5 headers is always running at 100% and is unchangeable in BIOS or using the Easytune software.
Surprisingly there's very little information about this issue around the forum or indeed the whole internet. The only solution mentioned is a non released BIOS.
I like the idea of dynamically adjusting fan speeds depending on what heat the cpu is producing rather than just undervolting and hoping for the best.
I'm hesitant to update to a non-official BIOS due to the loss of the overclock settings.
Is there any way to fix this without a BIOS update?
If not and want to update BIOS will the oc.uk saved settings work in a different BIOS or do I have to go back through and manually set the same settings again?
Many thanks.
Many thanks.
