*** OcUK Value 2GB (1x2GB) DDR3 10666C9 1333MHz Memory Module @ £26.99 inc VAT ***
Suspended
18 Oct 2002
OcUK HQ
*** *** OcUK Value 2GB (1x2GB) DDR3 10666C9 1333MHz Memory Module @ £26.99 inc VAT *** ***
OcUK Value series PC10666 DDR3 1333MHz are base on industry standard with exceptional build quality for OEM and system upgrade market in mind.
- 1333MHz DDR3
- CAS 9-9-9-24
- Unbuffered
- Lifetime Warranty
- 1.55 Volts
- 240 Pin DIMM
Only £26.99 inc VAT.
ORDER NOW
just tried three of these on a UD5
managed 1500mhz on them at 1.66v
they do run toasty - chose some third party heatspreaders
can confirm that the packaging is A-DATA
Buying two of these seems to be the only way to get 4GB of DDR3 dual channel RAM for less than £60 anywhere.
Four 1GB Sticks? That's going to be good for the memory controller... still, you can get some in some places when it's in stock, but it's not often. Hopefully that will change with the i5s.
It is Adata Retail product. And an absolute bargain price considering the current memory pricing situation.
This is one 2GB stick. Therefore 2 sticks of 2GB = 4GB.
Where exactly is the confusion? :p
