I currently have Realtek HD onboard audio and Logitech Z5500 speakers.
Do I plug them directly into the onboard audio OR plug them into the Z5500 control unit?
If I connect them to the Z5500, do I hook it up to the PC Optical/Spdif?
Also, if using analogue to connect the Z5500 to the PC with Windows set to output 5.1, when I plug the headphones into the Z5500, I assume the audio will be messed up so I need to set the Realtek to stereo as well?
Thank you.
Thank you.
