Which DDR3? (Given the low stock!)
5 Mar 2007
Macclesfield
Hello,
About to hit buy on a new 955BE PC (785G Chipset) and have no idea regarding DDR3 memory, as stock levels are low it’s looking like one of the two below, the first is ~£10 dearer, are there any differences performance wise between the two?
OCZ Platinum AM3 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel
http://www.overclockers.co.uk/showproduct.php?prodid=MY-167-OC
Corsair XMS3 DHX 4GB (2x2GB) DDR3
http://www.overclockers.co.uk/showproduct.php?prodid=MY-154-CS&groupid=701&catid=8&subcat=1387
Cheers
id go for the corsair, cheaper and can not see any real difference except that the corsair seems to have been tested better from the info we're given, however the revies of the corsair are not as good,,, depends how "dear" that £10 is to you?
Also looking around it seems to be the case for most suppliers.
So I expected were going to just get done over on the prices.
Hello,
Cheers
The below are now in stock, are these better than the above?
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit
http://www.overclockers.co.uk/showproduct.php?prodid=MY-037-GS&groupid=701&catid=8&subcat=1387
