- 29 Jun 2005
- London
I'm trying to get a cooler for my m-itx system that will fit into the really small space.
Currently I have an Akasa: http://www.overclockers.co.uk/showproduct.php?prodid=HS-054-AK
The problem with that is it's at full whack all the time, no PWM support, and the only PWM friendly cooler I can figure out that fits is the low profile stock cooler for the E8400.
I only have about 40mm(ish) clearance and the AC Freezer 7 won't fit due to the NB heatsink.
My question is; Is there anywhere you can get Intel coolers on their own? I know I can't get a direct answer, due to the competitor rules on here, but if I'm on a wild goose chase, then it'd be handy to know!
I've advertised on the MM Wanted section, so if anyone has one they don't need, please reply via this link - http://forums.overclockers.co.uk/showthread.php?t=18049050
Ta!
Ta!
