Deffo get a 1080p screen if you have good eyesight. To me, the difference between 1080p and 720p is clear.
If you don't have good eyesight, then just get a 720p. The pixels will be bigger and you'll be able to read text on your HTPC better.
.This is how I feel too.
I'd definitely go 1080P if using it as a computer monitor...... having problems with my X800GTO. Not sure if it's a driver problem (can't seem to get the proper ATI drivers installed and I think it's using the Microsoft implementation), or that it doesn't like 1080P over VGA. Might have to end up buying a HDCP graphics card and DVI->HDMI to get the full 1080P. Any thoughts?
If Quidco tracks I think about £390,
Just post some image![]()
)My TV (which is a different make/model) only does 720p over VGA. For 1080p it's HDMI only
Were you using the windows 7 drivers?Manged to get 1080P over VGA, but had to use an nVidia card instead of ATI as the drivers just wouldn't install on my Windows 7 machine!
