Yeah I'm not getting any problems but I think I made a mistake with the beta bios F10e on my UD3P because POST is slower with this cpu and the windows 7 bootup animated orb thing has a lower framerate - can't downflash to previous BIOS either it seems!
Once Windows hasloaded the logon screen it's all flying like normal though.
Just wondered what the plastic thing was for I guess!
Do you mean the white plastic square that goes in the middle back plate?
Ah didn't realise that could be done!
If by white you mean clear then yes I guess![]()
I think if you ask here http://forums.tweaktown.com/ you will find the answer to downgrading your bios.
