5870 1.6 x faster than 4870
5870 is about 60-70% faster than the 4870 in contemporary games on average - I imagine in more complex games using newer features that margin would widen.
5850 can only really be speculated at as less has been revealed about it, most of the specs banded about show the core being around 18-20% slower than the 5870 but crippled by a slower memory speed bringing it down to anything upto 40-50% slower depending on the final configuration and how sensitive to memory bandwidth it turns out.
Outside of the speculation from Fudzilla and VRzone, there's no evidence to suggest 5870 will be only 60% faster.
VRzone and Fudzilla are reporting the same thing, yet VRzone state a doubling of shaders at 1600 and fudzilla state 1200, so it's obviously still speculation.
Even if teh 60% faster thing was accurate, its more likely they'll be using figures from dx11 demo's, dx10.1 demo's and games. The 4870 series does dx10.1, which is a bunch of the decent performance improvements included in dx11. In otherwords it might be 60% faster in say, Assasins creed in dx10.1, that would make it more than 60% faster than a 280gtx in the same game, as Nvidia current cards can't do dx10.1, the 4870 in dx10.1 gets a massive boost in performance already.
As for doubling of performance, realistic doubling across the board in the majority of games hasn't happened for a long time, since the 9700-x800 days.
You make a VERY good point there.
Until we see some real world benchmarks or actualy find out what they are basing their 1.6x faster mubo jumbo ON we have no idea what the cards are actualy going to be like in current games.
If the quotes of 60% are correct, then surly that will be with very little driver development or maybe using algorithms.
You could easily add another 30% with driver development could you not ?
The 4800 series over the 3800 series seemed to manage the whole doubling performance thing rather nicely, I thought.
will wait for 6 months until the 5870x2 has come down to an affordable price (under £300), will have the Nvidea cards to compare them to then, tbh theres nothing i cant max out on my monitor at the moment so im in no rush to but anything :L)
It will likely be in 2560*2000 or whatever res with max AA, where you get 30fps with the 5870 vs 20 fps with a 4870, the lower the settings you go the less of an improvement it will be.
The 295 is two cards but a lot of games will only use one of the cards. a 4890 is loads faster in this situation. Same go's for the 4870x2.
It won't be "loads" faster. A little bit maybe, but a 295 is just two underclocked 275's stuck together, so you're comparing 4890 performance, to around 260 performance. It isn't LOADS faster. Also, I'm pretty sure most games benefit from SLI/Crossfire now, at least, the ones that need it do.
All half-decent modern games will run nicely under CrossFire or SLi. Jigger, please stop banging the 'dual-gpus are evil' drum; it's getting old now.
Well a 4890 give's a 260 a very hard time. One half of the 295 performs close to a 260 and a £126 4890 on ATI favoured games will whoop a 260. alah loads faster in this circumstance. Hence me saying you cant compare the new ATI card to a 295 gtx as dual GPU cards performance cant relayed on.
The point is, high end dual cards, and high end single cards cant be directly compared.
Aside from sim type games which for some reason always seem to run poorly if at all with multi GPU, multi GPU support with good performance scaling is now widespread with most games, some need profile updates tho.
Refulx please stop pretending all games support Dual GPU's, its still not the case.
Never said that, check your facts before you post :)
Whilst support is still not 100%, it's good enough that multi-gpu systems are popular and perform well, and are thus worth buying.
Have you ever owned a CrossFire or SLi setup? I've owned three, and whilst the dual 3870s were flaky as, the other setups were great.
