Saved a few gig of disc space but not noticed anything else.
I find this Snow Leopard change half-assed, because they still use "GB" elsewhere to refer to base 2 quantities (e.g. 4GB RAM).Is it actually a good amount of space or is that down to changing from base 2 to base 10 numbering?
My only issue was iphoto was missing.
I have two issues;
first: good old Office 2008seems to load Word, etc slower than before.
second: SL doesn't have Apple Loops which is a shame as I use them in Logic. I'm sure my Time Machine has backed them up but I'd appreciate a walkthrough on how to restore them to the correct location from someone if possible.
64-bit Kernel and Extensions: Yes
I bought a MBP about 3 weeks ago and one of my mates said if you bought any Mac in the last few months you could get the Snow Leopard upgrade for free?
Is there any truth in this or will I need to buy it?
Wake on LAN isn't a new feature![]()
doubt it but you can get it for £7.95
How do I go about getting it for that price?
I've got an iMac also which is about 18 months old so would probably be wanting to upgrade both. What would be the best option for this?
