- 18 Oct 2002
- Xbox Live
The next door neighbor has a virus on her daughters laptop. Typical teenage girl, got a "Check this out" message through MSN and clicked on it.
All hell has broken loose on the computer, it downloaded an app called Total Security (I think its version 4.52) which is claiming to be able to resolve all the problems for a fee. (modern extortion if you ask me)
Anyway the computer has Norton 360 on it, so I downloaded the updates and ran a quick scan (as the full scan required the backup settings to be configured which hasn't been done)
Nothing came up. Now its plain to see there is something not right with the laptop, its sluggish and doesn't always respond to your actions
I tried to look at task manager but it was closed as soon as it opened.
Ditto cmd.
I suspect there is more than just Total Security on there (which upon a bit of surfing is most likely some dodgy malware.) There are programs which claim to remove it but I'm not sure of their authenticity.
I also suspect that the virus(s) on the machine are hindering Norton's attempts to detect them.
I tried downloading adaware however it either never got to the Save as box or when I clicked run it downloaded and died. Again I suspect the virus(s) are fighting back.
I was a bit tired last night so I said I'd download the latest av and malware software today and see if I can install and run it... however I suspect I may struggle to install it (I cant remember if you can or cant install software in safe mode)
So my Plan on dealing with this computer is
A) Boot into safe mode
B) install av and malware software until something finds and removes the viruses
C)Reboot back to normal mode and see if everything is back to normal
Failing the above I was planning on taking the HDD out (its a laptop, so is this possible) and hooking it up to my PC and running AV/Malware software until clean.
Failing that I'll try to save all documents to a CD and see if I can run a recovery from the recovery partition and failing that either rebuild or send them to the purple shirt brigade.
Any hints/tips would be much appreciated.
Ditto cmd.
