*** This Week Only Offers ***
Suspended
18 Oct 2002
OcUK HQ
*** *** Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - OEM @ £199.99 inc VAT *** ***
Ultra Overclockable D0 Stepping (SLBEJ) Version to allow the highest overclocks and lowest temperatures possible. Achieve 975 performance at 920 pricing.
Nehalem is a radically new design for Intel: for the first time, the CPU is a 'native' quad-core CPU, where all four cores sit on the same piece of silicon. With its Core 2 CPUs, Intel used two dual-Core dies to create a quad-core chip, this translates into better performance. Nehalem features Level 3 cache, something first seen on earlier Xeon server chips, but Intel Core i7s will feature up to a massive 8MB (shared between all four cores). Each of Nehalem's four cores has 256KB of lower-latency Level 2 cache.
The Level 3 cache of Nehalem is described as being ‘inclusive’, meaning that it holds the data of all the Level 2 caches. This means that if a core needs to fetch data, and it doesn’t find it in the Level 3 cache, it can be confident that the most up-to-date version of that data is held in system memory and fetch straight from there. If the Level 3 cache wasn’t inclusive, the core would first have to look at the cache of the other three cores to ensure that none of them had a more recent version of the data it needs. An inclusive cache is therefore said by Intel to be more efficient than an ‘exclusive’ cache design, even if it does mean that 1MB of Nehalem’s 8MB Level 3 cache is taken up by storing a copy of the 256KB Level 2 cache inside each processing core, again this translates into a performance gain over Intels previous designs.
Intel has integrated the memory controller onto the Nehalem CPU die rather than having it be part of the Northbridge on the motherboard. It's achieved this by modularising the design of the CPU. The seperate processing cores and caches are linked to the onboard memory controller via a new bus standard called QuickPath (sometimes called QPI, short for QuickPath Interconnect). As QuickPath replaces the Frontside Bus (FSB) and Northbridge combo, it also takes over the role of allowing the CPU to connect to other system components, busses and controllers such as the PCI Express controller and DDR3 memory.
The last big news about Nehalem is that it uses Hyper-Threading. This technology works just as it did with the Pentium 4, using spare resources of a processing core to try to execute a second process thread. This means that a quad-core Nehalem processor can accept and attempt to process eight threads simultaneously, making it even more massively parallel than the current Core 2 Quad CPUs.
- Lithography Process: 45 nm
- Cores: 4
- Threads: 8
- Frequency: 2.66 GHz
- Cache: 256 KB L2/core and 8 MB shared L3
- Memory Controller: Triple channel DDR3 800/1066/1333 MHz
- Bus Interface: 1x 4.8 GT/s QuickPath
- TDP: 130W
- Socket: LGA1366
- D0 Stepping (SLBEJ) for extreme Overclocking
- This is an OEM Product and is not supplied with heatsink and fan
Only £199.99 inc VAT.
ORDER NOW
*** *** Intel Core 2 Quad Q9450 LGA775 'Yorkfield' 2.66GHz 12MB-cache (1333FSB) Processor - OEM @ £129.98 inc VAT *** ***
They're here! The CPU that everyone has been waiting for has finally arrived and it doesn't intend to disappoint! Using the new improved 45nm-process technology and various core improvements (inc SSE4) over the previous 'Kentsfield' model this new 'Yorkfield' technology is the absolute market-leader in performance and annhialates the competition and benchmarks alike. Want the best? The new Q9000-series from Intel is undeniably it.
- Intel Wide Dynamic Execution - Enabling delivery of more instructions per clock cycle to improve execution time and energy efficiency
- Intel Intelligent Power Capability - Designed to deliver more energy-efficient performance
- Intel Smart Memory Access - Improving system performance by optimizing the use of the available data bandwidth
- Intel Advanced Smart Cache - Providing a higher-performance, more efficient cache subsystem. Optimized for multi-core and dual-core processors
- Intel Advanced Digital Media Boost - Accelerating a broad range of applications, including video, speech and image, photo processing, encryption, financial, engineering and scientific applications. Now improved even further on 45nm versions with Intel HD Boost utilizing new SSE4 instructions for even better multimedia performance
- Quad Core Technology
- 45nm-process Technology with various Core technology improvements
- 2.66GHz clock speed (8x Multiplier)
- 12MB L2 Cache
- Intel Speedstep Technology
- EM64T 64-Bit Technology
- Execute Disable Bit
- Cooler running technology, less heat and less noise!
Only £129.98 inc VAT.
ORDER NOW
*** *** Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9) @ £87.99 inc VAT *** ***
The XMS Series TR3X6G1600C9 is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s high performance heat sink which includes Intel’s Extreme Memory Profiles (XMP 1.2). This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 9-9-9-24 at 1.65V VDIMM.
- Each three module set is tested at 1600MHz
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.65V, at latency settings of 9-9-9-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.65V
- 6144 Megabytes of DDR3 memory
- Three matched 2GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Only £87.99 inc VAT.
ORDER NOW
*** *** Corsair XMS2 4GB (2x2GB) DDR2 PC2-8500C5 TwinX Dual Channel (TWIN2X4096-8500C5C) @ £47.99 inc VAT *** ***
The XMS brand family is Corsair's mainstream line of performance memory. These modules allow users to experience outstanding memory performance and stability.Simply pop in this 4GB 1066MHz CL5 DDR2 memory kit into your system and see the difference in performance. If you are looking for extra performance or reliability in your Intel or AMD DDR2 system, the Corsair 4GB 1066MHz DDR2 memory kit offers this solution!
- Density: 4GB (2x2GB Module)
- Speed: 1066MHz
- Timing: 5-6-6-18
- Type: DDR2
- Format: DIMM
- Pin Out: 240
- PinVoltage: 2.1V
- Lifetime Warranty with Corsair
Only £47.99 inc VAT.
ORDER NOW
*** *** Corsair XMS2 4GB (2x2GB) DDR2 PC2-6400C5 TwinX Dual Channel (TWIN2X4096-6400C5C) @ £43.99 inc VAT *** ***
- Two matched 2GB modules for use AMD and Intel DDR2 systems
- Mainstream 800MHz solutions
- Latency of 5-5-5-18 for maximum reliability and performance
- XMS Heat Spreader
- Limited Lifetime Warranty
- Speed: 800MHz
- Timing: 5-5-5-18
- Type: DDR2
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.8V
Only £43.99 inc VAT.
ORDER NOW
*** *** Powercolor ATI Radeon HD 4890 1024MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail @ £120.98 inc VAT *** ***
The ATI Radeon HD 4800 Series GPUs bring the power of graphics ‘supercomputing’ to gamers, setting a new standard for visual computing. Redefine the way you play and take HD gaming to the extreme with best-in-class performance. The new TeraScale graphics engine delivers an immersive, cinematic gaming experience. Add this GPU to your PC and watch Blu-ray movies and play HD content with incredible visual fidelity. Do it all with break-through efficiency that doesn’t compromise performance.
- ATI Radeon HD 4890 GPU @ 850MHz
- 1024MB GDDR5 Memory @ 3900MHz
- 24x custom filter anti-aliasing (CFAA) and high performance anisotropic filtering
- PCI Express 2.0 support
- ATI CrossFireX Multi-GPU Technology
- Microsoft DirectX 10.1 support
- Shader Model 4.1
- ATI Avivo HD video and display technology
- Unified Video Decoder 2 (UVD) for Blu-ray and HD Video
- Built-in HDMI with 5.1 surround sound support
- On-chip HDCP
Includes:
- CrossFire Bridge Chip
- 6 Pin to 4 Pin Power Adaptor
- DVI to VGA Adaptor
- DVI to HDMI Adaptor
- HDTV Component Adaptor
Only £120.98 inc VAT.
ORDER NOW
*** *** Dell S2409W 24" Widescreen LCD Monitor @ £184.99 inc VAT *** ***
Experience stunning detail and clarity with full High-Definition resolution. Ideal for multimedia entertainment, gaming and productivity. Enjoy the latest movies and blockbusters in their highest resolution available. The HDMI connector interface allows simple transmission of uncompressed digital streams.
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 1000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 576.96mm x 416.19mm x 222.6mm
- Warranty: 3 Years On-Site
Only £184.99 inc VAT.
ORDER NOW
*** *** XFX ATI Radeon HD 4870 512MB GDDR5 PCI-Express Graphics Card @ £85.99 inc VAT *** ***
The ATI Radeon HD 4800 Series GPUs bring the power of graphics ‘supercomputing’ to gamers, setting a new standard for visual computing. Redefine the way you play and take HD gaming to the extreme with best-in-class performance. The new TeraScale graphics engine delivers an immersive, cinematic gaming experience. Add this GPU to your PC and watch Blu-ray movies and play HD content with incredible visual fidelity. Do it all with break-through efficiency that doesn’t compromise performance. With enhanced memory architecture that is able to handle 115GB a second, the ATI Radeon HD 4870 is the only graphics card available with blazing fast GDDR5 memory. Featuring nearly one billion transistors and up to 800 stream processors, the high resolutions and fast frame rates that were once the sole domain of dual-card systems are now yours.
- ATI Radeon HD 4870 GPU @ 750MHz
- 512MB GDDR5 Memory @ 3600MHz
- Shader Model 4.1
- On-chip HDCP
- 2 Year Warranty
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA/ testing terms and conditions (http://www.overclockers.co.uk/support.php)
Only £85.99 inc VAT.
ORDER NOW
but wasn't that the processor that was like £203 last week?
It is the best price I've seen it but still not a major saving compared to what if has been recently
