- 7 Jul 2009
- Newcastle/Aberdeen
Why the 920? That's basically slightly better than an 810, but without the advantage of a lower TDP. You should be looking at the 955.
WD's model codes don't tell numbers directly buth 750GB models has been using 3x250GB platter config and 640 2x333GB with shortstroking meaning (333/250-1)x100 % higher STR.I'm not sure what the performance difference will be between the 750gb wd green caviar and the wd 650gb caviar.
Second number is 5, not 9.So basically, the phenom 995 is on par with the core 2 quad the 9950.
