******* Xigmatek Case IN STOCK NOW ********
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Xigmatek MidGuard Midi Tower - Black (No PSU)
Midgard - home of mankind and protected by Thor, God of thunder, and his hammer. Signalizing the strength of diviness and mercy, but at the same time proprietaring the hardware you built in. Combined design and features such as black coated SECC and steel mesh are spotlighting your chassis when your system is built. Furthermore this chassis is supplied with 2 x 120mm pre installed fans (orange blade and black, transparent housings), but another 5 fans can be mounted in different areas for best possible airflow. 5 x 5.25" bays will be able to house all your optical drives, but also 5 trays for your 3.5" and 2.5" HDDs are available so you can feel free by "DIY". Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for pc beginners.
- Material: Steel Chassis
- Anti Vibration rubber on PSU compartment
- 5.25" External x 5 (One bay with 5.25" to 3.5" adapter, tool-free)
- 3.5" Internal x 5 (Tool-free)
- Cooling: Front Fan 120mm white LED with orange blades x 1, Rear Fan: 120mm white LED with orange blades x 1 (Preinstalled), Side Fan: 80/90/120/140mm fan x 1 (optional) 120/140mm fan x 1 (optional), Bottom Fan: 120/140mm fan x 1 (optional), Top Fan: 120/140mm fan x 2(optional),
- I/O Port: USB2.0 x 2, e-SATA x 1, Audio x 2
- Dimensions: 206 x 510 x 477 mm
Only £54.99 inc VAT.
BUY NOW
I like the look of this, dunno what ya got against it. Orange is good (orange g15 + those fans = woop woop). As that tech power up review states, its got lots of expensive features at not a bad price. I just disagree with selling the window as extra, I think it should come with that as standard with the solid pane extra. So yer, thats my next case to get :)
Yeah, i quite like the look of this. Think the budget case market is becoming saturated though... no matter how many better alternatives there are people still suggest the Antec 300.
*sigh*
I think the case looks really good! but I'm still sticking to me Lian Li ;)
Case looks good apart form the VGA connectors which are like they use to be on old cooler master cases I was never a fan.
Now you have their cases, heat sinks, now for their fans. :D
I remember having a thermaltake tsunami which had similar pci card clips, they werent very effecive at holding large graphics cards in place, i ended up removing them and just using screws, not a bad looking case though.
The internal are EXACTLY the same as a Coolermaster CM690 minus the colouring....
Any chance Xigmatek commissioned Coolermaster to make it for them?
Quite like the looks of it to be honest and anything that will help people stop buying the sodding god awful Antec 300 is ok in my book...
Not a bad case. From first looks the only thing I dont like is the sideways on Hard drives. Impedes that front airflow.
Good price with good features though. I would consider it for a reasonably budget build, but would probably got he extra for a Lian Li PC7.
Xigmatek make quite good PSUs as well...even a 1500 W version, but they havent been around long enough to really make their mark.
i've got their fans, plus i brought Thor's Hammer yesterday..... which is a really nice looking cooler, pure quality; but this case, flipping heck!
