I do wonder about these. With a 1600rpm fan the air coming out the back of a 60mm thick feser is pretty close to the same temperature as the water, doubling the thickness will only decrease airflow. I take it these are meant to be used with high pressure/high speed fans?
Cracking rad ran my i7 920 @4ghz 1.23v in a single loop with northbridge/southbridge and mosfet 35-38c idle 65c odd loaded with low cfm yate loons with better fans the temps could have been better.
