- 26 Mar 2009
- Ashington , N/land UK
Hi,
Current hardware
Prolite E2403ws
Pentium D CPU 2.8 ghz( 2 cores)
ASROCK 775Dual-VSTA Mobo
BFG 9500 GT 1 gb PCI-e 2.0 (16)
Createive SB Audigy 2 Zs with SB 7.1 sourround sound
2 gig RAM ddr2
750 w PSU (not SLI)
and a couple Bluray(sata) / DVD drives
The machine has developed a habbit of killing Sata drives 3 X 320GB Seagates in past 6 months and now one of the the IDE seems to be going the same way..
so looked over and upgrades bios etc and everything seems ok, so thinking should just maybe look at a new machine.
Had this one for a couple of years and runs ok ...but not brilliant
Have ordered windows 7 for October and looking at 64 bit
been pricing i7 bundle (OC or AWD-IT) against buying components seperate.
Have rebuilt pc a few times and fine with that..but never oveclocked...and no experience of windows 7 / 64 bit windows or the I7 just seen some very very good reviews and again some really bad ones..i.e no good for gaming..wait for i5...)
SO roughly pricing
I7 920 + maybe Gigabyte EX58-extreme /ud5 (any thoughts)
6 or 12 gb mem
initially keep graphics card but maybe spend 50 quid on adding another of the same so that I can SLI (good or bad idea?)
adding 2 x 1.5 tb sata 2 drives (seagate barracuda)...not sure what other damage has been done to exiting drives..
(currently running with a 1 tb external backup drive...just incase more of the current drives fail)
Cooler master 932 (although did see a rather nice tsunami ..but only want to spend max 150 on case)...(ideas )
Will need to add a new power supply..what is good for I7 750 (with sli)...>?
Sound card ....will this run (or should I replace ...fairly happy with it..but not sure if it will work in 64 bit..and have had no issues with HD)
so thoughts please, I want a pc that will maybe last me a couple years ....I am trying to re-use some components but this is so that i can divert cash to other parts of the build and replace those later ...but if it gonna be a bad idea then can investigate)
Will be looking at October for getting this procured ( so not want to buy before i get w7 as prices of some components / better components for similar money may come out (and obv they will not be installed until Oct so will loose some warrenty)
cheers
Ray
Current hardware
Prolite E2403ws
2 gig RAM ddr2
750 w PSU (not SLI)
SO roughly pricing
6 or 12 gb mem
cheers
Ray
