Clutch (like Carmageddon)
I want to play Carmageddon again!!!
The DOS 3DFX version runs fine on Windows XP using VDMSound and a Glide wrapper. You can force it to run at 1600x1200 or whatever resolution you want. Not tried it under Win7 yet though.
I believe the Win95 version should run fine under XP with no faffing, but then you're limited to 640x480 res (with the -hires switch, 320x200 otherwise)
Carmageddon got me into Iron Maiden :D Loved the soundtrack on the 2nd game. Used to blast it out of my awful PC speakers at the time
