I'm building a new passive system and it will definitely have an EK Supreme CPU block and an EVGA GTX200 HydroCopper 16 GPU block on a GTX280.
It will also use a single five-stick Konvekt-o-Matik to cool all of it.
Now, I have two reservoirs - the XSPC Dual DDC and a selection of 10W and 18W DDCs and a Typhoon III with a Laing D5 Vario in it.
The options available are;
Typhoon III and 1 loop
Typhoon III and two loops with the CPU on one loop and the GPU and radiator on the other
Typhoon III and two loops with the CPU and radiator on one loop and the GPU on the other
XSPC Dual DDC with one 18W DDC and 1 loop
XSPC Dual DDC with two 10W DDCs with the CPU on one loop and the GPU and radiator on the other
XSPC Dual DDC with two 10W DDCs with the CPU and radiator on one loop and the GPU on the other
I could also use two 18W DDCs but that seems like massive overkill to me.
My thought process is this - the Supreme really benefits from a high flow rate, so if I give it it's own mini-loop with a DDC it will be working optimally. As the reservoirs in both cases are shared, the water coming back from the radiator will be common to both and once equilibration has occurred, it won't matter.
Thoughts?
Thoughts?
