Hello, i recently got the crosshair III motherboard which came with a very smart looking sound card. i didnt use the sound card at first as i used a usb headset.
I just purchased a better headset with analogue so i could once again use a sound card.
Anyways, when the card is plugged in, it lights up so the motherboard is supplying the power to it but my system wont recognize that it is plugged in. Its not listed in device manager and when i try to install the drivers it says i dont have the hardware.
(it's in the right slot as per the motherboards instructions, i have no other sound drivers installed now, nothing disabled in bios)
At first i thought it likely to be a defected card, but i have read a couple of other instaces of peolpe in the same situation with the same messege when trying to install the drivers. Unfortunately i havent seen a clear solution to the issue so i thought id see what you guys thought.
Thanks
Thanks
