Windows 7 oem upgrade.
14 Aug 2009
Just ordered windows 7 through the upgrade option, will I get both 32bit and 64bit cd sent to me. When I was on the order page I saw that it said I was ordering a 32bit windows 7.
Ok would I receive an activation key for the windows 7 32bit cd and if i do would i be able to use the key on a 64bit bit windows 7 backup cd.
You will have 32 Bit Windows 7 then. Keys are interchangable, so if you want 64 Bit order the Media from MS.
I doint think you can use a 32bit key on a 64bit OS it never used to work anyways, maybe they have changed it for win 7?
Can you confirm this?
You'd also have to order the 32-bit media from MS - all you'll get is Vista 32-bit media. You have to send off for the Windows 7 updgrade after October 22nd.
