Sounds like it could be an overheating issue or a PSU issue.
In your bios do you have a auto-system shutdown feature enabled if the system temps reach a certain level? Some comptuers do and when that is reached they just power down instantly.
Regardles 96degrees on an 8800 is pushing it a bit, people say the cards are designed to get to near 100 but getting right on the mark is pushing your luck.
Have you tried taking the side of the case off and using a deskfan as extra ventillation? It doesn't help much but it will help enough to test it to see if it is overheating that's the problem. Then you can address it properly...
I think the main thing to do may be to get a new case to be honest... but I can't see myself fitting all this into a new one
Your going to struggle I think. Without looking into it you may find that Packard bell like to keep things non-standard so you always have to go back to them for repair.
If your gpu is getting hot try cleaning it out and cleaning everything else out really![]()
Not checked, but you're probably right, it may have those setting on it... I've use a desktop fan to cool down a PC before, so will give that a try definitelyI think the main thing to do may be to get a new case to be honest... but I can't see myself fitting all this into a new one
did packard bell sell that pc with that psu?
Does no-one know if it would be possible to transfer the Motherboard to another case?
Depends on if packard bell use a standard form factor or not. IIRC, Dell don't so you can't on them. If it's ATX/Matx you'll have no problems.
You need to download Rivatuner & use it to turn your GFX fan to 100% permanently. I think the new Nvid drivers have dropped everybodys fans to 60%, Summit like that anyway.
How do I check that?
Not sure tbh. Could download CPU-Z, google the Motherboard you get and it should tell you the form factor.
) chipset it nForce 730i
The motherboard is a FMCP7AM, made by Packard Bell (which may kill it) chipset it nForce 730i
Anyone know if that could fit into another case?
That doozy has worked too many times for me
Take the motherboard dimension measurements, also take note of where the holes are on the board that screw down into the case you are in.
I would imagine if you get a big enough case, most motherboards are designed to be able to fit into many cases. Just check it out in comparison to a potential case you could buy.
Unless it's a mini/HTPC or something similar?
Glad the suggestion of case off and deskfan seems to have temporarily fixed the issueThat doozy has worked too many times for me
