- 7 Jul 2009
- Newcastle/Aberdeen
Some people have complained that their Titan has fallen apart...
Cheers for the tips on that, I'm not into doing lapping, just need a simple cooling solution. Take the mobo out is about as far as I'm prepared to bother.
Looks like it's now between sunbeam and titan.
ok, if you're not into lapping then this one below is very good too:-
http://www.overclockers.co.uk/showproduct.php?prodid=HS-003-XG&groupid=701&catid=57&subcat=1395
because to be honest, the Thor's hammer is a waste of money unlapped,/ dual fans...you'd be better off with a True or the one above
Well im running with a Titan and did some research before i brought it and mine is not falling apart.![]()
Frostytech gives the CCF better temps than the Fenir on AMD systems, but just a tiny bit worse on Intel systems.
I thought you were going to get the CCF? But yeah, they should all come with the appropriate mounting hardware.
Meh, it's okay. I prefer the CCF though. Also with the really big coolers you have to be careful when moving them.
I wasn't talking about if it would fit or not, i was talking about moving the case. You could snap the motherboard with a really heavy one.
remember, most of these big tower coolers need push/pull for max cooling
They do? Oh, ok, didn't know that. I thought the pushpin was just another method instead of screws, didn't realise it also has an important role in the cooling process. Unless anyone wants to talk me out of it, I will buy the Sunbeam CCF as first suggested by Superewza and I thank you all for your assistance and patience![]()
no sorry, i mean push/ pull 120mm fans.... your mounting system is ok
