No sorry, I didn't mean the bios flash, my wording was a bit confusing between bios flashing, and core unlocking.
I meant, if the unlock worked but was unstable or didn't boot into windows, would removing the cmos battery reset the bios to seeing the cpu as dual core again? In other words, can I lock the cores again to re stabilise the system?
As it happens, I just flashed the bios, and boy, did I have a scare! Everything went fine with the @BIOS utility, and it was set to load cmos default after updating bios. However, after seeing "verifying DMI data.. success" it wouldn't boot into windows, it kept going into that screen where you can choose normal or safe modes. Turns out that it had changed my boot up sequence to floppy drive, AND the order of the hard drives was changed too from my windows installed sata drive to one of my ide drives. Lol, thank god I spotted that
Now the bios shows an addition.. EC Firmware. It's set to normal but it can be changed to 0.82, and this works along with ACC. So it doesn't say hybrid, but I believe EC firmware is fine?
Btw, now my cpu is running at 47, where before it was always 36 to 39.
Bios can change temp?
