- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Silverstone RV02 Raven 2 Case - Black (No PSU)
After releasing the ground-breaking RAVEN RV01, the first retail chassis to utilize the 90 degree motherboard mounting layout, SilverStone’s RAVEN team quickly went back to the drawing board to create another chassis with even more mass appeal. The resulting RAVEN RV02 is smaller, lighter, and higher performing. Compatibility with Extended-ATX motherboard and server level storage capacity were sacrificed in favor of a more compact dimension and consumer oriented design. Three custom designed 180mm fans and one 120mm fan are included in the RV02 to provide noise to cooling performance ratio that breaks existing benchmark for enthusiast chassis. Additional features such as the inclusion of the 8th expansion slot (for triple or quad graphics cards), all black painted interior, custom designed hard drive suspension cage, and radiator mounts completes a package that will not only appeal to hardware enthusiasts but also to anyone looking to assemble a system that makes a statement with plenty of cooling and very little noise.
- Material: Reinforced Plastic Shell, with Steel body
- Motherboard Compatability: ATX, MicroATX
- Drive Bays: 8 x 5.25"
- Drive Bays: 3 x 3.5"
- Drive Bays: 1 x 2.5"
- Cooling: 1 x 120mm top exhaust fan, 3 x 180mm bottom intake fans
- Front I/O: 2 x USB2.0 and 2 x Audio
- Dimensions: 212 x 503 x 643mm (W x H x D)
Only £114.99 inc VAT.
BUY NOW
BUY NOW
