- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit @ £96.99 inc VAT *** ***
Corsair's mainstream memory solution for Intel.s new Core i5 and Core i7 dual channel DDR3 processors. The XMS3 family is Corsair.s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance
and stability. Available in Corsair.s new XMS heat spreaders, each module is built using carefully selected RAMs.
This 4GB twin kit memory solution has been designed to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 8-8-8-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock.
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3
- Intel Core i5 and Core i7 processors
- 1600MHz
- Voltage: 1.65V
- Latency of 8-8-8-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Only £96.99 inc VAT.
ORDER NOW
- 1600MHz
- Voltage: 1.65V
- XMS Heat Spreader
ORDER NOW
