*** Intel P55 Launch - The Memory ***
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit @ £96.99 inc VAT *** ***
Corsair's mainstream memory solution for Intel.s new Core i5 and Core i7 dual channel DDR3 processors. The XMS3 family is Corsair.s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance
and stability. Available in Corsair.s new XMS heat spreaders, each module is built using carefully selected RAMs.
This 4GB twin kit memory solution has been designed to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 8-8-8-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock.
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3
- Intel Core i5 and Core i7 processors
- 1600MHz
- Voltage: 1.65V
- Latency of 8-8-8-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Only £96.99 inc VAT.
ORDER NOW
*** *** G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit @ £73.99 inc VAT *** ***
The F3-12800CL7D-4GBRH is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- Each module pair is tested together at 1600MHz
- Tested and packaged in pairs
- Packaged together immediately following system test
- SPD programmed at: JEDEC standard 7-7-7-24 values at 1600MHz
- 4096 Megabytes of DDR3 memory
- 1.65 Volt Tested
- Using DHX technology providing maximum cooling
- 100% tested at 1600MHz in high performance DDR3 motherboards
- Lifetime warranty
Only £73.99 inc VAT.
ORDER NOW
*** *** Corsair XMS3 DHX 4GB (2x2GB) DDR3 1600C9DHX Twin3X @ £69.99 inc VAT *** ***
The TW3X4G1600C9DHX is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using Corsair’s latest high performance heat sink with Dual-Path Heat Xchange (DHX) technology. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at the low latencies of 9-9-9-24.
- Tested together at 1600MHz, Vdimm = 1.80V, at latency settings of 9-9-9-24
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz
- Two matched CM3X2G1600C9DHX modules
- Supports Socket AM3 AMD Phenom II processors
- Lifetime warranty
Only £69.99 inc VAT.
ORDER NOW
*** *** Geil Ultra Series 4GB (2x2GB) PC3-17000 2133MHz Dual Channel Kit @ £84.98 *** ***
GeIL introduce the all new DDR3 Ultra line of products added to the performance memory module lineup. DDR3 is the next-generation memory for personal computing, servers and other computing applications. It is now the highest performing memory with official data transfer rate that doubles the speed of the DDR2 architecture with much lower power consumption.
- 4GB Dual Channel KIT
- CAS: 9-9-9-28
- 2133MHz Clock Speed
- FBGA 128Mx8 DDR3 Chips, 240 pin, Non-ECC, Un-buffered DIMM
- Neo-Metallic-Blue Aluminum Heat Spreader
- Working Voltage: 1.65V
- Lifetime Warranty
Only £84.99 inc VAT.
ORDER NOW
They pay for the forums, I think they can advertise where they like!
With all due respect, we pay for the forums every time we buy something... but fair call it is theirs to do what they will. Still I think being a many time repeat customer of OcUK I have some right to voice my opinion regarding it's structure and content even if it isn't taken notice of.
If I want to find out about new hardware releases then I check out the hardware section, I don't expect to have it waved infront of my face in every single section that I visit.
+1.
No doubt it will irritate some people, possibly even to the point of losing sales in some cases. OTOH, I'm sure they gain a lot of sales from people who'd not otherwise have noticed the products because they don't regularly visit the relevant hardware sections.
I'm sure they've done their homework and concluded that the latter outweighs the former and it's thus a worthwhile exercise :)
