- 7 Mar 2005
- Northumberland
As title. I have an OEM version of vista home premium. If I dropped a Q6700 cpu in would vista allow me to do this under the terms of the licence?
Yep load bios defaults then remove the old cpu and pop the new one in.
Before you swap just check that your Bios will recognise the new chip( you may have to update it); vista should not, hopefully, be a problem.
