If it's the old-style ABS-like plastic bumpers/trim that have the odd texture (which are pretty much the only ones to fade), then use a blowtorch on them.
Clean the plastic thoroughly, then gently wave the blowtorch over it, from a few cm away, and as you do so, the heat will bring the natural oils in the plastic back to the surface. Typical disclaimer here - it's at your own risk, don't be a muppet, don't hold the blowtorch too close or over the same part for too long, don't hold it over the paintwork, etc.
This method will keep the plastics looking in an "as-new" condition for longer than any other method that might be suggested - such as mustard, WD-40, Back-To-Black products, other than the exception of painting them body-coloured - but that's a much bigger task to undertake.
Post up a picture - and I'll tell you if it's the type that able to be used with a blowtorch.
