Teenager invents £23 solar panel that could be solution to developing world's energy
Sure it is. The definition of electromotive force (voltage) is the work or energy which causes the flow of an electric current.
The voltage of a cell is a measure of the amount of energy per coulomb of charge, it's not a measure of the energy output of the device. The point was that energy is measured in Joules, not Watts or Volts.
yes, other than the fact theres very little proof it works, except what seems like clearly a much higher wattage bulb than the claimed 18w, being lit by it.
First bulb looks like a standard mains fitting... no way it would be that bright off 9v 18watt or so...
The 2nd one is possible to get for camping in 12v 11watt configuration... so that might be possible.
Energy per unit of charge =! energy
They're totally different, just as an acceleration is different to a velocity.
Least it looks a more credible than Steorn :p, what ever happened to their free clean energy device? Been 2/3 years now, after the 'studio lights were too hot' demo.
I think newspapers have a responsibility to be as correct as possible with these kinds of things. The Daily Mail is one of the harshest critics of our education system, yet seems oblivious to the fact its own pages are full of inaccuracies and sometimes plain untruths.
Ok, ok. :) Even so, I think his point was regarding the reporter's misunderstanding of the conversion between the two, not the difference between centripetal and cetrifugal forces. ;)
I'm certainly not going to argue with someone with the nick of Energize, but my understanding of voltage, whether AC or DC, was the potential energy between a source to ground. If it ain't required, it ain't going to be used. *sic*
"Perhaps you need a refresher course!"
Yes, I do. :D
