What improvements to my original overclock did you do Bulldog. I'd like to see what you did.?
I will explain to you one more time, my last one of how do I improvement it.
1) Putting 2 x apache fans to the back rear case to replaced antec 1200 fans.
2) 2 x apache fans on the cpu cooler with a push-pull. (please note: this is not a Corsair H50 anymore. Using a Prolimatech Megahalems cpu cooler)
3) Rotate clockwise the cpu cooler facing the rear back fans.
4) Set the fan speed from low to medium of my exhaust big fan (200mm) on top of the case.
5) A new MX-3 thermal paste applied a very thin layer on the cpu chipset and the heatsink of the cpu cooler plate with a credit card. No dot in the centre.
6) Moved my graphic card from slot 1 to slot 3 away from the cpu cooler.
7) Lower in vcore voltage by 2 more lowers than 1.287v. (now at 1.275v at the bios and 1.184v at the cpuz)
8) Will going to installed 3 more apache fans at the front of my case to be replacement antec 1200 fans. These should be a lot of improvement on the airflow exspecially 7 x apache fans on the case.
Hope this help you mate.
EDIT: the full reading of my easytune6 as following: cpu temp: 43C, north bridge temp: 32C, system temp: 24C, gpu temp: 34C and 4 fans of 1400 rpm (apache fans) and room temp: 25C (during my overclock at full load)
