Windows 7 sitting on the welcome screen for too long
5 Jun 2005
Southampton
oh the joys of upgrading to win7!
my laptop was trouble free but my shuttle is being a pain!
my pc sits on the "O Welcome screen" for ages when logging in either on the network or off the network, i only have nod32, as a non windows proggy loading at startup. It was fine on Vista
by google'ing i have found it could be the nforce drivers, however the windows ones seem to be the only ones! when i download the nforce drivers from the nvid site it says it's for
Windows 7 64-bit Driver Versions:
•GPU Driver (v185.85) WHQL
•Ethernet Driver (v73.06) WHQL
•Network Management Tools (v73.05) "Sedona"
•SATAIDE Driver (v11.1.0.23) WHQL
•SATARAID Driver (v11.1.0.23) WHQL
•RAIDTOOL Application (v11.1.0.23)
•SMU Driver (v1.67) WHQL
•Installer (v7.01)
however when i run the installer it says it will only install
Can you install the devices manually - through device manager and then navigate to the driver in the C:\nVidia\packagename folder.
This would cover everything except the network management tools (which I would not install) and the RAIDtool which you would only need if you have a RAID array setup for status, rebuilding, diagnostics etc.
my boot log has a warning
+ System
- Provider
[ Name] Microsoft-Windows-Diagnostics-Performance
[ Guid] {CFC18EC0-96B1-4EBA-961B-622CAEE05B0A}
EventID 100
Version 2
Level 3
Task 4002
Opcode 34
Keywords 0x8000000000010000
- TimeCreated
[ SystemTime] 2009-09-10T15:18:12.847000000Z
EventRecordID 44
- Correlation
[ ActivityID] {00000100-0000-0000-486E-04672932CA01}
- Execution
[ ProcessID] 1220
[ ThreadID] 2000
Channel Microsoft-Windows-Diagnostics-Performance/Operational
Computer Shuttle
- Security
[ UserID] S-1-5-19
- EventData
BootTsVersion 2
BootStartTime 2009-09-10T15:14:33.687200000Z
BootEndTime 2009-09-10T15:18:08.993800000Z
SystemBootInstance 19
UserBootInstance 16
BootTime 33820
MainPathBootTime 17520
BootKernelInitTime 21
BootDriverInitTime 1382
BootDevicesInitTime 4367
BootPrefetchInitTime 34636
BootPrefetchBytes 307830784
BootAutoChkTime 0
BootSmssInitTime 6245
BootCriticalServicesInitTime 1864
BootUserProfileProcessingTime 353
BootMachineProfileProcessingTime 77
BootExplorerInitTime 0
BootNumStartupApps 3
BootPostBootTime 16300
BootIsRebootAfterInstall false
BootRootCauseStepImprovementBits 8388608
BootRootCauseGradualImprovementBits 0
BootRootCauseStepDegradationBits 0
BootRootCauseGradualDegradationBits 0
BootIsDegradation false
BootIsStepDegradation false
BootIsGradualDegradation false
BootImprovementDelta 0
BootDegradationDelta 0
BootIsRootCauseIdentified true
OSLoaderDuration 2592
BootPNPInitStartTimeMS 21
BootPNPInitDuration 4385
OtherKernelInitDuration 1518
SystemPNPInitStartTimeMS 5773
SystemPNPInitDuration 1364
SessionInitStartTimeMS 7268
Session0InitDuration 1466
Session1InitDuration 1259
SessionInitOtherDuration 3519
WinLogonStartTimeMS 13513
OtherLogonInitActivityDuration 3575
UserLogonWaitDuration 105919
just tried that but it says there is nothing to be added. just seems to hang for around 20 seconds before letting me in
I had this problem with an nVidia based machine, but the driver I had probs with was the SMBus one :s
I just chose an older version from the nVidia site extracted the drivers and manually installed them. Are you trying to install them through Device Manager - Update driver, Browse My Computer, then navigating to the respective folder in C:\nVidia\xxx\ and getting this message?
Not much help I know but I had the same problems trying to install the 64bit version on my lappy. Reverted to win 32 version as couldn't be bothered to find the cause. Was quite weird... Does it sound like it's searching from the disk too?
FIXED!! i created a new profile and then there was no issue what so ever, i think i must have buiggered it when i copied files over from vista... you know the hidden ones and so on!
