yes i've lapped mine, but it wasn't too bad in stock form.... not nearly as bad as the Thor's Hammer, that really does need lapping; it has quite deep machining marks on it, but once lapped it looks gorgeous.
the Megahalems has a plated underside and is supposed to be slightly bowed on purpose.......... but i lapped mine regardless.
600 grade and then 1200............stick the WET and DRY to a piece of glass, damp it with water.
move the cooler slowly...apply no pressure, just let it skate backwards and forwards...turn it through 90 degrees once every 30 seconds..
it takes about 5 mins on 600 grade and then about 15 mins on 1200...
you're not after a perfect shine, but perfect flatness........... because if you do it right it'll shine anyway.
you can lap it with 1200 only, but it'll take a lot longer to get it flat.
i like doing it, it's so relaxing.....
i'll give you a tip, dont move the cooler with your arms, pivot your body back and forth via your pelvis, keep your chest and arms fixed stiff and your elbows tight to your chest, this will prevent the Cooler rocking.......... this gets the cooler flat very quickly.
............do not change from the fore to the back stroke quickly either, because this will rock the cooler too.....
