Which would you choose?
Man of Honour
17 Feb 2003
Chelmsford
I5 system :
Gigabyte GA-P55-UD5 Intel P55 (Socket 1156) DDR3 Motherboard £169.99
(£147.82) £169.99
(£147.82)
Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - Retail £159.99
(£139.12) £159.99
(£139.12)
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-12800 1600MHz Dual Channel + 3D Mark Vantage (PVV34G1600LLKB) £80.99
(£70.43) £80.99
(£70.43)
Sub Total : £357.37
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.00
VAT is being charged at 15% VAT : £54.96
Total : £421.33
or
i7 1366 system
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - Retail £209.99
(£182.60) £209.99
(£182.60)
Gigabyte GA-EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard £194.98
(£169.55) £194.98
(£169.55)
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel (PVT36G1600LLK) + 3D Mark Vantage Benchmarking Software £83.98
(£73.03) £83.98
(£73.03)
Sub Total : £425.18
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 15% VAT : £65.20
Total : £499.88
£78 difference..
920 system has 2gb more memory, higher 3x bandwidth.. but is it more overclockable?
What do you think?
When listed like that - the possibilty of of a better clock (4GHz), more memory/bandwidth - the i7 1366 system looks far more appealing for the extra - £78.
This for you, Huddy?
When listed like that - the opportunity of a better clock, more memory/bandwidth - the i7 1366 system looks far more appealing for the extra - £78.
This one is.. I built an I7 for a customer a few months ago and was well impressed. I've been looking at the i5 posts this week and 4.2Gb is easily achievable so wondered if it was actually worth going for over the i7 when more chips are on the way on the 1156 platform ... Not sure if 1366 is going to last?
+1 for such a small difference, I'd go for the 1366.
However, for the 860 it's not so clear cut. As a games machine I'd choose the 860.
Comparing just those bundles, with only a £78 difference, the LGA1366 i920, at a shot.
However, if you're putting a full system togeather, you'll probably have some sort of budget restraint. If the £78 meant a much better GPU or monitor, or if it meant a decent keyboard and mouse vs a basic setup, then I could see the i5 becoming more attractive. It's not like there's a big difference in performance.
LGA1366 insn't going anywhere in a hurry, it's going to be around as long as LGA1156.
Also people are more likely to pair the 750 with a budget mobo like the UD2, I know why you included the UD5, like for like comparison and all, but I doubt many people would be buying high end mobo and budget CPU, more likely other way round
A tough, bet an ultimately enjoyable, decision to make...
You have a legendary chip in your present rig so you may be ‘slightly’ under whelmed with the performance with what ever setup you eventually get. But the fun is in the tweaking and new hardware so either would fulfil that criteria.
95thriffles, as you’ve noted, makes a valid point – so if budget was a factor you could make the difference less appealing?
Additional: But I, personaly, couldn’t resist the draw of the 1366 i7: triple channel memory and the opportunity to stick another 6 gig in at a later date and have a serious play with RAMDisk. Plus, you’ll no doubt be sticking the whole thing under water(?) so you may be looking at 4.2/4.4GHz clock that would make the system have considerable longevity.
I'm tempted to get one myself - but it's hard to justify the expense, although i do need to build an HTPC out of this e5200...
