I've not been an atheist since I was about 15 when I had the limitations of science explained to me.
Huh?
You mean you started your O-Levels/GCSEs found it a tad tough and caught religion?
Huh?
Or he realized that atheism is basically as faith based as religion and became an agnostic.
But it's funny how you try and attack religious people as being dim when you hold basically the same beliefs![]()
Huh?
I do? I do?
Atheist.
I admire people with faith, and if that gets them through life then good on them. Everyone has right to a belief.
The irony of it being called faith seems to be lost on them though.
You're an atheist you have faith in an unprovable assertion, do you admire yourself in the mirror?![]()
I have faith in nothing.
Atheist.
As far as I am concerned religion came about for one major reason, to control the masses. Secondly, the reason it still exists today is because the hunman mind cannot contemplate the fact that when you die, you are dead. Remember before you were born, well its like that.
iirc you've repeatedly stated you don't believe in a god and that you believe it's more likely we are the remnants of alien experiments.
Where do I state that?
I think its far more likely that humans on this planet are the results of "Aliens". Be it a failed experiment or a Prison planet. Just seems far far more likely than some god like being. Unless by "god like" it simply means "more advanced".
What's interesting is that it is far FAR more likely that we are an experiment/left behind by beings most likely nearly identical to Humans. Than there is some uber mystical being that requires you to bow down in supplication facing the correct direction. Or cares if you go into a building with a pointy roof on Sundays.
I work with a born again christian. He takes great pride (sin) in having a reputation in not trying to convert.
He actually is a really nice bloke. BUT. He gets stuck at one point when I put this accross. I say to him, as a Christian you are bound to certain rules, which of most of them are pretty much common sense but when I say "me as an athesit, I surely have a better moral compass than you, as I do not fear hell, I do good things because I am a good person, but he obviously does it out of fear.
I ask you, who is the better person. The man who realises we are worm food but does good deeds, or the man who thinks he wont get into heaven if he doesn't?
ownedWhere do I state that?
Atheist.
owned
does not compute.
there.
