Silverstone RV01B-W Raven Case
16 Sep 2008
Southampton
Bit of a radical design. Motherboard is at a 90 degree angle with the I/O shield in the top. Never seen that before.
Review: http://www.3dgameman.com/content/view/14580/103/
http://www.overclockers.co.uk/showproduct.php?prodid=CA-062-SV&groupid=701&catid=7&subcat=1092
What you guys think?...not sure if it would work tbh.
Personally prefer a simpler design without all the vents, sliding front panel etc.
Before watching that video I thought it sounded an aweful idea... But after watching it I can see how much of a really good idea it is!
Wont be leaving my mountain mods behind though!
The angle of the motherboard is good for graphics cards with heavy after market coolers on - the cards no longer bend under the sheer weight! Some good ideas there, but the amount of plastic is a little off putting.
The door looks like fail as it will hit the knobs on a fan controller by the looks. Made of plastic and no removable mobo tray??? Also the chav light on the front looks crap as well.
Anybody got one of these yet? be interested in some pictures of a build. I'm considering this case as well as the fortress and even one of the temjin range.
WhiteKnight
im going to buy this case but i dont know if putting my P55 M-ATX would be worth it.
I love the sliding door! but im going to use this case forever for future builds. I expect it to break in about 2-3 years or maybe less if i play with it to much!
