I need to block all websites with the word "bingo" in it
Status
Not open for further replies.
19 Oct 2002
Torbay, Devon, UK
Hi all
I need some help urgently.
I need to block every bingo website. I am using WRT54G with tomato firmware 1.25. I can block www.website.com etc but I need a more overall block of the word bingo. As I can not list every site.
Im hoping it can be done via the router and not extra software.
Regards
Clairvoyant
Generally a router cannot do keyword blocking, they dont have the processing power for it.
Your need some type of guardian software. That is mainly developed to stop kids from accessing wrong sites.
Also why Bingo :P
You could always lock the machine down at the router and not allow it access at all but to the sites you add to the list...
There might be a browser plugin if you'r using firefox but you would have course then have the problem of the missus using IE for example.
ok lots of options for this
- use opendns as the dns servers and block sites through that
- use safesquid or websense or similiar, basically a proxy with content filtering
- change the default gateway on the pc so she cant access the net (or pull cable out etc)
- use something like foxfilter to content filter in firefox - https://addons.mozilla.org/en-US/firefox/addon/4351
but that only stops her accessing the bingo sites on the net, and she will probably throw a wobly when she sees what youve done
Get the addresses of all the sites you wish to prevent access to from her browsing history. Add them to the hosts file with the address of 127.0.01. Or even sneakier make the ip address 216.239.59.104 (google). She'll probably be baffled and won't have a clue how to circumvent this.
make a massive thread about it in GD
then after a few days of people bashing her, send her the link, it may get through to her :(
good luck mate
Status
