** New Lian Li Cases ** IN STOCK
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Lian Li PC-A70FB Full Tower Case - Black (No PSU)
In 2009, Lian Li have introduced the unbeatable PC-A70F for the PC gaming enthusiasts, and gaming professionals who want a high quality product with a unique flavor. The PC-A70F is manufactured in TAIWAN; handcrafted from high quality aluminum and incorporates Lian Li’s finest workmanship which has built up over more than two decade’s worth of experience.
- Material: Aluminium
- Motherboard Support:
- 5 x 5.25" Drive Bays
- 11 x 3.5" Drive Bays
- System Fan(front): 140mm Blue Fan x 2 (1000RPM)
- System Fan(Rear): 120mm Fan x 2 (1500RPM)
- I/O Ports: USB2.0 x 4, FireWire x1, e-SATA x1, Audio x 1
- Dimensions: 220mm x 590mm x 585mm ( W x H x D)
Only £169.99 inc VAT.
BUY NOW
Lian Li PC-A71FB Full Tower Case - Black (No PSU)
The PC-A71F is manufactured in TAIWAN; handcrafted from high quality aluminum and incorporates Lian Li’s finest workmanship which has built up over more than two decade’s worth of experience. PC-A71F has hair-line brush anodized aluminum finishing with diamond cut detail. The look of PC-A71F has been desighed with a door panel system; ensuring the case is virtually silent, made with an all aluminum alloy chassis, simple with minimalism stylish look.
- Motherboard Support: E-ATX / ATX / M-ATX
- System Fan(front): 140mm Fan x 2 (1000RPM)
- Dimensions: 220mm x 590mm x 615mm ( W x H x D)
Only £199.98 inc VAT.
BUY NOW
Lian Li PC-A06FB Mini Tower Case - Black (No PSU)
The idea for creating PC-A06F, is to save user's space, and no need to use poor performance hardware, PC-A06F can fit standard ATX motherboards, power supply and powerful graphics cards. With a unique rear side mounting adjustable PSU adapter bracket whihc allows the PSU to be semi-outside of the chassis thus providing lots of room and helps to cool the interior of your system.
- Motherboard Compatability: ATX & M-ATX
- 4 x 5.25" Drive Bays
- 3 x 3.5" Drive Bays
- Cooling: 1 x 140mm Fan (front) 1 x 120mm Fan (top)
- I/O Ports: 2 x USB2.0 & 2 x Audio
Only £75.99 inc VAT.
BUY NOW
:o ..oops, not sure how I missed that, but I did. Arhh well, they are about £50 more expensive than I was expecting though.
I can see why my Cosmos 1000 cost £140, it's quite obvious, from the pictures it isn't so obvious why the PC9 does, I gather it must be made from much heavier grade aluminium than the PC7, more like the V series I would hope ?
Never owned one, never will
They are pretty good, certainly above average, the V series is very good though, but there are better, the Coolermaster Cosmos is better 'built' than any Lian Li I have seen (a lot, owned 3 myself, including a V1000) ...but the best there ever was is still the old Colermaster ATCS cases from way back.
I have an ATCS 210 myself, although I don't use it for anything I quite often just have a good look and feel of it when I'm in the loft :p ...it's just so beautifully made, it's hewn not cut and crafted not manufactured. They really don't make them like that anymore.
