Mens Hair Mousse, recommendations.
Status
Not open for further replies.
24 Oct 2005
North East
Lo all.
Was wondering if anyone knows a nice mousse to use thats ok for dandruff sufferers i.e doesnt flair up when u use it. As before when i used to use it this was 10+ years ago lol. It used to really be bad for my head causing bad dandruff so avoided it. Now im just curious if theres anyone that has the problem but found a decent enough mousse to use.
My first thought as well.
Come to think of it, what does mousse actually do? Is it like hair gel or something?
Yes, it fixes your hair without it looking like it has any product in it (unless you use too much).
Don't know any anti-dandruff versions though. Are you sure it wasn't just the mousse itself? It comes out like dandruff after it's been on all day.
Look for 'dermatologically tested' brands if you're concerned.
[FnG]magnolia;14896208 said:
I'd suggest American Crew hair waxes. They're very good, if quite pricey.
They also leave a distinct shine, which mousse tends not to.
Mousse and hairspray are the only two that fix defcently and don't really loook that noticable, unless you overdo it.
How do you know this? Did you learn it at finishing school?
Really good matte finish with this.
It's used by the kind of men who call hair stuff "Product".
They arn't actually men, just women who have really let themselves go.
Well the cream ones tend to be too well thick too apply and never got on with em, mousse is easier to apply.
And i hope the mods remove some of the posts in here.
Status
