- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Lian Li PC-X1000 Full-Tower Case - Black (No PSU)
The new TYR series, PC-X1000 is the case which functionality and style converge. Open the side panel with the tool-less latch, the removable motherboard tray, HDD racks, 3 x140mm silent intake fans with filter, top mounted multi-media I/O ports, and the graphics card holder have been redesigned – because when it comes to your comfort, every detail counts.
- Super Full Tower Chassis
- Motherboard Compatability: ATX / M-ATX
- Dimensions: 230mm x 680mm x 430mm ( W x H x D)
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 3 x 5.25" drive bay (External)
- 6 x 3.5" drive bay (Internal)
- System Fan (Front): 140mm Ball-Bearing Fan x 3 (1200RPM)
- System Fan (Rear): 140mm Ball-Bearing Fan x 2 (1200RPM)
- I/O Ports: USB2.0 x 4, IEEE1394 x 1, E-SATA x 1 and HD+AC97 Audio
Priced at only £336.98 inc VAT.
Pre-Order Now
Pre-Order Now
