PRE-ORDER *** Lian Li PC-X1000 Case ***
if the price is to do with the cooling, then you will only get to a certain temp due to the ambient air around the case and if you are that bothered about temps and want to spend that much then you could just watercool for a lot less with a smaller case :)
James Manns! didnt really answer a single question really did you!
Water cooling in a case which already has very good air flow would not cool the cpu any better than an air cooler because as you probably already know a watercooled system is also limited by the ambient air temperature unless the system includes an evaporater which i have never seen in a case due to water drawn in by condensation!
lets try again!
really! you can get an i7 setup for £264! where at?
Does it matter if the inside isnt painted if you cant see it?
just to give me an idea! which other case with similar aesthetics, space and cooling performance would you recommend?
Looks = stunning
Price = *faints*
End of the day yes it is silly expensive and I wouldn't pay it myself but having had 2 Lian-Li cases in my time I can vouch for the build quality, they are extremely well made and do look awesome, if you got the cash for an insane high end build then why not! :D
i wasnt trying to start a argument on this, and i was going on the price of 300 something someone told me,
the inside of the case isnt seen but it looks the part and at least you can re-paint parts whereas with polished ali its a lot harder to remove a scratch.
its just a lot for something that in a few years will be outdated.
