Team OcUK stats site down
25 Mar 2007
NE England
As above. http://teamocuk.co.uk site shows "Closed for maintenance".
"Status last updated: Wednesday, 22nd April, 12:55 UTC".
I seem to remember the above date refers to an extended outage from a few years back.
If it is genuinely down for maintenance now, can you please at least update the page to show the correct date (it would also help if you included the year as well).
Otherwise, please kick the web server back into life.
Cheers.
Looks fine to me, now :)
Either it was just doing a db update or something else automated, or, berserker saw your friendly email and gave it a prod :)
Ooh, matron! You want me to make changes? That'll cost you. :p
Odd. No idea what happened there. Probably an admin on one of the servers having a play. :confused:
PS - I've removed the old outage message and added a generic one.
Graphs are now working, but only on www.teamocuk.co.uk. If you try it without the www., you'll still see the error.
PS - if this doesn't work for you, you've got a badly-behaved DNS cache.
PPS - the site should also be slightly faster as a result of this change, as I've done away with the split data/web server and put everything in one place.
Top man zerker it's all looking good from where I'm sitting - now if it only updated every three hours like stanford... you might alreday have noticed a small rise in production.
Parp, Parp Biffa, number 10 will be mine :D
Oops - the server doesn't have freetype support. I'm running a system update script on the server overnight as it's a bit out-of-date. I've included the change that should fix this so hopefully it will go away.
Gah, another path I'd forgotten to change. 5 second fix.
SETI classic stats are broken too but no-one looks at those anymore, do they? :D
Cheers mate - I just wanted to post this:
cpartcert1.php
M
